kann mir jemand sagen welche Festplatte das ist ? Unter der Seriennummer finde ich nichts in der Suchmaschine. Verbaut in einem Amstrad 1640.
Amstrad baute nie Festplatten. Mach einmal Fotos von der Ober- und Unterseite
Gruss
Peter
PC1640HD20 - Alps DRMD20A12A (service manual states that Tandon drives were used too)
https://marc.info/?l=classiccmp&m=130713436717927&w=2
List: classiccmp
Subject: Info on Amstrad 40095/A / DRMD20A12A MFM HDD
From: Philip Pemberton <classiccmp () philpem ! me ! uk>
Date: 2011-06-03 20:51:34
Message-ID: 4DE94956.6020506 () philpem ! me ! uk
[Download RAW message or body]
Hi guys,
Someone has just donated an old ST506 hard drive to the DiscFerret
project... This time, it's an Amstrad drive, with part number 40095/A
"DRMD20A12A".
Thing is, I can't seem to find any information on it -- and at the very
least I need to find out what the CHS settings are in order to create a
DriveSpec file.
Here are a couple of photos:
Top of drive:
http://twitgoo.com/2bnvcy / http://i52.twitgoo.com/n7yp.jpg
PCB:
http://twitgoo.com/2bnvdl / http://i53.twitgoo.com/2cgzc0k.jpg
Major chips are:
Hitachi HD63B01Y0P
SanKen STA435A
Hitachi HA13426
CF77143FT
SSI 540-3CH S8714 32119.1.1F
Hybrids: SC619 and SC628
Text at top corner of PCB near power connector: PY349C
Head stepper motor is labelled:
TYPE 103-4902-0320
10.5VDC 0.26A 0.9 DEG/STEP
LOT NO. 05709I
6035095-1
Form factor is 3.5-inch, half-height (about the same height as a 5.25 HH
MFM drive)
From what I can gather, it's a 20MB MFM drive, with four heads --
there's a sticker on the top which reads:
DEFECT:CYLINDER
HEAD0
HEAD1 327 386 426 504
HEAD2
HEAD3 216
(The numbers are handwritten -- badly)
There's a second sticker along the edge:
W A R N I N G
WARRANTY VOID
IF THIS SHIELD
BROKEN
Does anyone have any idea what this thing might be?
Alles anzeigen
Take a closer look--the drive should be "DRND20A"--it's an Alps 20MB
unit--615/4/17 are the nominal ratings. 60msec. average access.
GrussPeter
Hallo Peter,
hab ich weitergeleitet. Der Rechner ist außer haus
vielen Dank für Info. Die Datei konnte ich aber nicht öffnen. Zumindest weiß ich jetzt mehr
Hier stehen noch einige Infos & Daten dazu ...
