After many trials and following troubleshooting tips suggested, the system display remains after many attemps, as follow:
Break
A=10 B=BD X=E0D7
C=D9 S=0112 P=011B
The system behaves as this:
Start by switch on : display appears after the "beep" tone" that I interpreted as encouraging, but:
Switch off doesn't clear the screen
Push on the reset button clears the screen
Some info about the machine:
Serial: 010884.
Should be running BASIC V1 and has the opening over the 6301 VOP C63010 CA
Basic M64030AA ROMS:
ROM0: A2X145
ROM1: A2X144
ROM2: A2X139
ROM3: A2X140
ROM4: Empty
RAM 0,1,2,3: M16010C (x4)
Dip switch settings: OFF ON ON OFF : French Keyboard (Membrane type)
Power supply: new sub-Cells (1500mAh) installed; recharged using the original transformer.
Battery circuit checked up to the capacitors
Flexprint and other flat ribbon cables checked.
Any suggestions are welcome and I would be more than happy to see this machine up-and-running again.
Many thanks in advance.
Andre
