Release v5.0 vom 15. Oktober 2023:
Tera Term
2023.10.15 (Ver 5.0)
Changes
Changed internal processing to Unicode.
Changed the folders to read setup files, the folder to save log files.
Changed default to on for High DPI support.
Same behavior as before the change when DPIAware=off add to Tera Term section in TERATERM.INI
Added setting Underline attribute(SGR 4) color and font
if log file name from command line or default log file name is not full path, now it is considered as relative path from log folder or default log save folder.
Exchanged foreground and background colors of characters that attributes is setted ANSIColor when colors are reversed with DECSCNM set.
U+00A0(NBSP) and U+2000..U+2003 are converted to SPACE and displayed. tree command output is displayed correctly.
XMODEM: Fix to check all received datas and process correctly, even if received datas are accumulated.
YMODEM: ignore continuous 'C' when waiting for sending.
Changed window position to specified in TERATERM.INI when duplicate a session.
added a setting that can disable corner rounding of VT Window and TEK Window in Windows 11.
added the WindowCornerDontround entry in the teraterm.ini file. The default is off.
changed behavior of Binary checkbox of Send file on file drop dialog.
now default state is TransBin value of TERATERM.INI.
now state is remembered when "Do same process, next drop" is checked.
Invalid characters as file name contains Default log file name, are replaced with '_'.
Bug fixes
Fixed problem with color number 1-7 and 9-15 are replaced in sequence OCS 4.
Fixed wrong color numbers in the color change and response sequence.
Fixed the area selected with the mouse does not disappear when the text is erased with the erase escape sequences.
Reset text colors when [Control]-[Reset terminal] is selected
Fixed wrong window size is set when NAWS (Negotiate About Window Size) is received on telnet (cygterm) connection.
Fixed mouse cursor style is changed to hand when mouse cursor hover on URL string even when clickable URL is disabled.
Fixed DPI adjustment does not work correctly when VT Window is moved to different DPI monitor.
Fixed Kermit could not receive in some case.
Adjusted packet size of Kermit send.
Fixed full color icon is not used to notify icon.
Fixed changed custom notify icon is not used to notify icon.
Fixed when SSH connected, "Do same process, next drop" is checked on "File Drag and Drop" dialog, nevertheless always "SCP" is selected.
Fixed current font name was empty in ChooseFont dialog when changing dialog fonts.
Fixed wrong color numbers were changed when the color palette change in Visual Tab in Additional settings dialog.
Fixed "Send file" help is appear when "Help" button is pushed on Log dialog.
Fixed wrong value is written to VTReverseColor when saving TERATERM.INI during reverse video.
Fixed when setting value of MouseCursor in TERATERM.INI is lower case, value is not loaded to "Additional settings" dialog.
The file handle of TELNET.LOG could not be closed.
MACRO: can not read from the file handle that is opened by filecreate command. This bug was introduced in 4.102.
MACRO: The setpassword command cause an error when password argument is a string value. Only string variable was accepted.
MACRO: The getpassword command updates password variable by undefined value when password from user is no input.
Misc
Changed requirements, Windows 7 or later.
Added about EAR (Export Administration Regulations) to Frequently asked questions.
Upgraded TTSSH to 3.0.
upgraded TeraTerm Menu to 1.17
upgraded TTXttyrec Plug-in to 1.05.
upgraded TTXResizeMenu Plug-in to 1.07.
NOTE: CygTerm+ binary included in the installer becomes to be supported on only 64bit Cygwin. Please build CygTerm+ from source code by using 32bit Cygwin, if CygTerm+ wants to run with 32bit Cygwin.
Deleted LogMeTT, TTLEditor and Collector.
upgraded Oniguruma to 6.9.8.
Alles anzeigen
