Where is that from? I checked my Pics of the original card and cannot find sich a bodge
It's from the pictures of the HR80 card.
Alles anzeigenNot for the HR-40B from what I can see in my photos - this is the for the HR80 though not sure I wired that in.. need to check the photos more.
Sorry you having so many difficulties - I have found the HR-40B boards quite robust apart from that ribbon cable attachment to the board and the yellow clip touching other pins. I changed the ribbon cable to a socket and pin arrangement.
I have even desoldered one board to take photos of the bare board and re-installed all the iC's and it worked though the ribbon cable attachment is fiddly and prone to breakage if not careful.
The random noise on the screen appearing when you draw seems a 74LS issue perhaps or RAM issue. I cannot recall seeing that before. Will pull my HR-40B and replica board out again and fire it up to see if we can figure it out. However, I soldered all my 74LS IC's onto the board rather than use sockets.
Thanks again guys for helping like crazy here!
At least both universal boards like the char EPROM.
The cable to the CRTC should be ok, I measured every single wire point to point.
Clearing the screen is ok, too. But drawing always results in dots + small horizontal lines in addition to the line to be drawn.
