News from the HR40B front!
After doing some work on my 4032 (it was reworked to 80 columns, so I had to reverse that first), I retested the ROMs posted and cross checked the connections... at least I found a wrong wire (white and black, were set to 20,21 and not to 21,22, J9).
ANNND: It works at least partially!
The commands work fine, SYS59650,5 will start the HR40b and SYS59650,C will clear the screen again. I can even make lines!
The bad thing: the curious vertical lines, we saw already at CBM_Ba 3032 still remain.
Puh, due to it works at least as intended, I assume all parts are working... due to we have the same issue at 2 machines: the problem either is on the HR40b (has anybody an idea where to start?) or the same issue on the Univ board (but I dont think so).
Any ideas are welcome!
