Ich fasst hier einmal zusammen, was ich bisher nützliches gefunden habe und (fast) täglich im Einsatz habe:
Magnifier Glasses 250 Degree Magnifying Eyewear Reading Portable Glasses Gift For Parents
https://www.aliexpress.com/item/32974607969.html
45X Handheld Reading Magnifying Glass Illuminated Magnifier Microscope Lens Jewelry Watch Loupe Magnifier With 3 LED
https://www.aliexpress.com/item/4000385624025.html
Connector Crimp Connection Terminals K1 K2 K3 K4 K5
https://www.aliexpress.com/item/4000083466232.html
Schnelle Kabelverbindung (z.B. innerhalb der PET/CBMs)
Inline 304 DC Switch On Off with Female Male Power Cable 5.5x2.1mm LED DC Connector Switch 5V 12V 24V
https://www.aliexpress.com/item/32942058069.html
Praktisch z.B. beim ZX Spectrum und allen anderen Rechnern mit Hohlstecker, aber ohne Schalter.
Essager Magnetic Cable For iPhone Samsung Xiaomi Micro USB Wire Cord Fast Charging Magnet Charger USB Type C Mobile Phone Cable
https://www.aliexpress.com/item/4000125100058.html
Ideal für USB-Geräte, die häufig im Einsatz sind
High Efficiency Test Hook Clip 300mm Logic Analyzer Cable Gripper Probe Test Clamp Kit Yellow/Red/Black/Green
https://www.aliexpress.com/item/4000600456508.html
Testkabel für Logic-Analyser
300Pcs/set M3 Black Screw Hex Nut Spacers Stand-off Kit Set Fastener Hardware With Box
https://www.aliexpress.com/item/1000007337581.html
PLCC IC BIOS Chip Extractor Removal Puller Motherboard Tools
https://www.aliexpress.com/item/32866671713.html
U Type Chip Extractor Removal Puller Pull Up Machine Clip Repair Tool Professional Tool Extractor Chip Puller
https://www.aliexpress.com/item/32885932367.html
50Pcs 1.2X15CM Reusable Cable Nylon Strap Black Cable Cord Hook and Loop Ties Tidy Organiser for Cable Winder
https://www.aliexpress.com/item/32863296962.html
USB 5V Charger power Cable USB to DC 5.5 mm plug / jack USB Power Cable For MP3/MP4 Player
https://www.aliexpress.com/item/32651798223.html
USB 2.0 A 1 Female to 2 Dual USB Male Data Hub Power Adapter Y Splitter USB Charging Power Cable Cord Extension Cable
https://www.aliexpress.com/item/32782030893.html
5V 2 Wire 2pin USB Connector DIY Copper Connect Cable for LED Strip Light desk lamp fan connecting
https://www.aliexpress.com/item/32798147571.html
Keyboard Keycap Puller Adjuster For Mechanical Keyboard Cleaning Tool Aluminium Alloy Multi-function Red Key Cap Remover
https://www.aliexpress.com/item/32813556228.html
Switching power supply source 110V / 220V To dc 5V 4A 5A 6A 10A 20A 60A
https://www.aliexpress.com/item/32998643643.html
https://www.aliexpress.com/item/32857490962.html
Praktische kleine Netzteile.
5W 9V 12V 24V to 5V DC DC Step-Down Buck Converter Module replace TO-220 7805 lm2596
https://www.aliexpress.com/item/32766296476.html
https://www.aliexpress.com/item/32826540392.html
https://www.aliexpress.com/item/33034496914.html
Praktisch für einige Rechner bei denen der 7805 zu heiß wird (ZX Spectrum)
